Load different Sequence via JS on HoloLens 2.
Hi all,
I have a question about Vuforia in interaction with HoloLens 2.
In my scenario, I need to switch between different sequences (that I created with Creo).
This should be done by clicking on a button. I know the underlying command via JavaScript and have already used it successfully several times - but so far only for iPad (2D) Experiences.
For this I always use:
$scope.view.wdg['model-1']['sequence'] = 'l-Creo%203D%20-%20sequence.pvi';
In the preview everything works as it should.
Now when I test my scenario on the HoloLens, it seems to me that the HoloLens does not know this command. It loads the "default sequence" of the 3D model. Generally, I can't jump between sequences....
Do you know what I am doing wrong? To me it looks like there is a bug in the HoloLens interpreter. Is there another command that makes jumping between sequences work on the HoloLens?
I am grateful for any help!
Many greetings
Jonas
