Model not steady
  • June 28, 2018
  • 1639 views
I made a project with a marker and a model on it. But when I look at it in the view the model jumps a bit and doesn't stay steady on the marker like I would expect it.
How big is the physical printer marker and what device are you using?
dieter1-VisitorAuthor
Half of a A4 paper
That sounds plenty big enough, i believe 3" is the recommended size. I would try another device (phone/tablet), some do track better than others. Also make sure you have plenty of light and are not trying to do this in a featureless white room or similar. I believe View likes to have visible room geometry to help build the tracking model from.
