Network connection requirements for Thingworx Studio - Trial
I've signed up for Thingworx Studio Trial version to develop an AR proof of concept. However, I could only login outside my company's network. When I try to login from my corporate network, I get the following log:
[11/19/2017 08:00:48] Studio Version 8.1.1 (8.1.1.2213)
[11/19/2017 08:00:48] Status Message: Version 8.1.1 (8.1.1.2213)
[11/19/2017 08:00:48] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[11/19/2017 08:00:50] Status Message: Performing First Time Setup (Application)...
[11/19/2017 08:00:50] Unzipping mbdist.zip to C:\Users\Chernyavskiy\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\
[11/19/2017 08:00:54] Status Message: Performing First Time Setup (Libraries)...
[11/19/2017 08:00:54] Unzipping mbmodules.zip to C:\Users\Chernyavskiy\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\
[11/19/2017 08:01:26] Starting node.exe
[11/19/2017 08:01:28] info: [twx-studio:initializer] Node version: 8.7.0
[11/19/2017 08:01:28] info: [twx-studio:initializer] ThingWorxStudio launched with the following arguments: _=[C:\Users\Chernyavskiy\Documents], help=false, version=false, $0=..\..\..\..\..\..\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\index.js
[11/19/2017 08:01:28] info: [twx-studio:initializer] ThingWorxStudio dir: C:\Users\Chernyavskiy\Documents\ThingWorxStudio , home dir: C:\Users\Chernyavskiy\Documents
[11/19/2017 08:01:29] ar-extension version 8.1.1 (1.19.750)
[11/19/2017 08:01:29] info: [twx-studio:index] Studio Ready: listening on 127.0.0.1:3000
[11/19/2017 08:01:29] Status Message: Version 8.1.1 (8.1.1.2213)
[11/19/2017 08:01:33] [0mGET /%7B%7B::projectType.imgPath%7D%7D [32m200 [0m3.534 ms - 2216 [0m
[11/19/2017 08:01:33] [0mGET /%7B%7B::view.imgPath%7D%7D [32m200 [0m3.208 ms - 2216 [0m
[11/19/2017 08:01:33] [0mGET /%7B%7B$root.currentProject.thingServerQRCode%7D%7D [32m200 [0m2.574 ms - 2216 [0m
[11/19/2017 08:01:33] [0mGET /%7B%7BviewType.imgPath%7D%7D [32m200 [0m2.621 ms - 2216 [0m
[11/19/2017 08:01:33] [0mGET /images/%7B%7B::w.name%7D%7D.png [32m200 [0m2.592 ms - 2216 [0m
[11/19/2017 08:01:43] info: [twx-studio:logging] Overwriting env DEBUG info:ves-publish*,error:ves-publish*,undefined with new value
[11/19/2017 08:01:43] info: [twx-studio:logging] Debug logging disabled
[11/19/2017 08:02:00] error: [twx-studio:auto_configure] 500 'Unable to retrieve service details.' Error: tunneling socket could not be established, cause=connect ECONNREFUSED 127.0.0.1:80
[11/19/2017 08:02:00] at ClientRequest.onError (C:\Users\Chernyavskiy\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\node_modules\tunnel-agent\index.js:177:17)
[11/19/2017 08:02:00] at Object.onceWrapper (events.js:316:30)
[11/19/2017 08:02:00] at emitOne (events.js:115:13)
[11/19/2017 08:02:00] at ClientRequest.emit (events.js:210:7)
[11/19/2017 08:02:00] at Socket.socketErrorListener (_http_client.js:385:9)
[11/19/2017 08:02:00] at Socket.emit (events.js:210:7)
[11/19/2017 08:02:00] at emitErrorNT (internal/streams/destroy.js:64:8)
[11/19/2017 08:02:00] at _combinedTickCallback (internal/process/next_tick.js:138:11)
[11/19/2017 08:02:00] at process._tickDomainCallback (internal/process/next_tick.js:218:9)
[11/19/2017 08:02:00] [0mGET /api/autoConfigure [31m500 [0m1041.949 ms - 58 [0m
[11/19/2017 08:02:00] error: [twx-studio:index] unhandledRejection Unable to retrieve service details.
[11/19/2017 08:02:01] info: [twx-studio:logging] Debug logging disabled
[11/19/2017 08:02:13] info: [twx-studio:logging] Debug logging disabled
[11/19/2017 08:02:23] Studio Version 8.1.1 (8.1.1.2213)
[11/19/2017 08:02:23] Status Message: Version 8.1.1 (8.1.1.2213)
[11/19/2017 08:02:23] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[11/19/2017 08:02:24] Starting node.exe
[11/19/2017 08:02:25] info: [twx-studio:initializer] Node version: 8.7.0
[11/19/2017 08:02:25] info: [twx-studio:initializer] ThingWorxStudio launched with the following arguments: _=[C:\Users\Chernyavskiy\Documents], help=false, version=false, $0=..\..\..\..\..\..\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\index.js
[11/19/2017 08:02:25] info: [twx-studio:initializer] ThingWorxStudio dir: C:\Users\Chernyavskiy\Documents\ThingWorxStudio , home dir: C:\Users\Chernyavskiy\Documents
[11/19/2017 08:02:26] ar-extension version 8.1.1 (1.19.750)
[11/19/2017 08:02:26] info: [twx-studio:index] Studio Ready: listening on 127.0.0.1:3000
[11/19/2017 08:02:28] [0mGET /%7B%7B::projectType.imgPath%7D%7D [32m200 [0m3.310 ms - 2216 [0m
[11/19/2017 08:02:28] [0mGET /%7B%7B::view.imgPath%7D%7D [32m200 [0m2.788 ms - 2216 [0m
[11/19/2017 08:02:28] [0mGET /%7B%7B$root.currentProject.thingServerQRCode%7D%7D [32m200 [0m2.908 ms - 2216 [0m
[11/19/2017 08:02:28] [0mGET /%7B%7BviewType.imgPath%7D%7D [32m200 [0m2.989 ms - 2216 [0m
[11/19/2017 08:02:28] [0mGET /images/%7B%7B::w.name%7D%7D.png [32m200 [0m3.006 ms - 2216 [0m
[11/19/2017 08:02:45] error: [twx-studio:auto_configure] 500 'Unable to retrieve service details.' Error: tunneling socket could not be established, cause=connect ECONNREFUSED 127.0.0.1:80
[11/19/2017 08:02:45] at ClientRequest.onError (C:\Users\Chernyavskiy\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\node_modules\tunnel-agent\index.js:177:17)
[11/19/2017 08:02:45] at Object.onceWrapper (events.js:316:30)
[11/19/2017 08:02:45] at emitOne (events.js:115:13)
[11/19/2017 08:02:45] at ClientRequest.emit (events.js:210:7)
[11/19/2017 08:02:45] at Socket.socketErrorListener (_http_client.js:385:9)
[11/19/2017 08:02:45] at Socket.emit (events.js:210:7)
[11/19/2017 08:02:45] at emitErrorNT (internal/streams/destroy.js:64:8)
[11/19/2017 08:02:45] at _combinedTickCallback (internal/process/next_tick.js:138:11)
[11/19/2017 08:02:45] at process._tickDomainCallback (internal/process/next_tick.js:218:9)
[11/19/2017 08:02:45] [0mGET /api/autoConfigure [31m500 [0m1031.224 ms - 58 [0m
[11/19/2017 08:02:45] error: [twx-studio:index] unhandledRejection Unable to retrieve service details.
[11/19/2017 08:02:46] info: [twx-studio:logging] Overwriting env DEBUG info:ves-publish*,error:ves-publish*,undefined with new value
[11/19/2017 08:02:46] info: [twx-studio:logging] Debug logging disabled
When I connected from an outside network, I could log in.
What are the network requirements for ThingWorx Studio?
Best regards,
Vladimir
