Network connection requirements for Thingworx Studio - Trial
vchernyavskiy
I've signed up for Thingworx Studio Trial version to develop an AR proof of concept. However, I could only login outside my company's network. When I try to login from my corporate network, I get the following log:
[11/19/2017 08:00:48] Studio Version 8.1.1 (8.1.1.2213)
[11/19/2017 08:00:48] Status Message: Version 8.1.1 (8.1.1.2213)
[11/19/2017 08:00:48] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[11/19/2017 08:00:50] Status Message: Performing First Time Setup (Application)...
[11/19/2017 08:00:50] Unzipping mbdist.zip to C:\Users\Chernyavskiy\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\
[11/19/2017 08:00:54] Status Message: Performing First Time Setup (Libraries)...
[11/19/2017 08:00:54] Unzipping mbmodules.zip to C:\Users\Chernyavskiy\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\
[11/19/2017 08:01:26] Starting node.exe
[11/19/2017 08:01:28] info: [twx-studio:initializer] Node version: 8.7.0
[11/19/2017 08:01:28] info: [twx-studio:initializer] ThingWorxStudio launched with the following arguments: _=[C:\Users\Chernyavskiy\Documents], help=false, version=false, $0=..\..\..\..\..\..\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\index.js
[11/19/2017 08:01:28] info: [twx-studio:initializer] ThingWorxStudio dir:  C:\Users\Chernyavskiy\Documents\ThingWorxStudio , home dir: C:\Users\Chernyavskiy\Documents
[11/19/2017 08:01:29] ar-extension version 8.1.1 (1.19.750)
[11/19/2017 08:01:29] info: [twx-studio:index] Studio Ready: listening on 127.0.0.1:3000
[11/19/2017 08:01:29] Status Message: Version 8.1.1 (8.1.1.2213)
[11/19/2017 08:01:33]  [0mGET /%7B%7B::projectType.imgPath%7D%7D  [32m200  [0m3.534 ms - 2216 [0m
[11/19/2017 08:01:33]  [0mGET /%7B%7B::view.imgPath%7D%7D  [32m200  [0m3.208 ms - 2216 [0m
[11/19/2017 08:01:33]  [0mGET /%7B%7B$root.currentProject.thingServerQRCode%7D%7D  [32m200  [0m2.574 ms - 2216 [0m
[11/19/2017 08:01:33]  [0mGET /%7B%7BviewType.imgPath%7D%7D  [32m200  [0m2.621 ms - 2216 [0m
[11/19/2017 08:01:33]  [0mGET /images/%7B%7B::w.name%7D%7D.png  [32m200  [0m2.592 ms - 2216 [0m
[11/19/2017 08:01:43] info: [twx-studio:logging] Overwriting env DEBUG  info:ves-publish*,error:ves-publish*,undefined  with new value
[11/19/2017 08:01:43] info: [twx-studio:logging] Debug logging disabled
[11/19/2017 08:02:00] error: [twx-studio:auto_configure] 500 'Unable to retrieve service details.' Error: tunneling socket could not be established, cause=connect ECONNREFUSED 127.0.0.1:80
[11/19/2017 08:02:00]     at ClientRequest.onError (C:\Users\Chernyavskiy\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\node_modules\tunnel-agent\index.js:177:17)
[11/19/2017 08:02:00]     at Object.onceWrapper (events.js:316:30)
[11/19/2017 08:02:00]     at emitOne (events.js:115:13)
[11/19/2017 08:02:00]     at ClientRequest.emit (events.js:210:7)
[11/19/2017 08:02:00]     at Socket.socketErrorListener (_http_client.js:385:9)
[11/19/2017 08:02:00]     at Socket.emit (events.js:210:7)
[11/19/2017 08:02:00]     at emitErrorNT (internal/streams/destroy.js:64:8)
[11/19/2017 08:02:00]     at _combinedTickCallback (internal/process/next_tick.js:138:11)
[11/19/2017 08:02:00]     at process._tickDomainCallback (internal/process/next_tick.js:218:9)
[11/19/2017 08:02:00]  [0mGET /api/autoConfigure  [31m500  [0m1041.949 ms - 58 [0m
[11/19/2017 08:02:00] error: [twx-studio:index] unhandledRejection Unable to retrieve service details.
[11/19/2017 08:02:01] info: [twx-studio:logging] Debug logging disabled
[11/19/2017 08:02:13] info: [twx-studio:logging] Debug logging disabled
[11/19/2017 08:02:23] Studio Version 8.1.1 (8.1.1.2213)
[11/19/2017 08:02:23] Status Message: Version 8.1.1 (8.1.1.2213)
[11/19/2017 08:02:23] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[11/19/2017 08:02:24] Starting node.exe
[11/19/2017 08:02:25] info: [twx-studio:initializer] Node version: 8.7.0
[11/19/2017 08:02:25] info: [twx-studio:initializer] ThingWorxStudio launched with the following arguments: _=[C:\Users\Chernyavskiy\Documents], help=false, version=false, $0=..\..\..\..\..\..\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\index.js
[11/19/2017 08:02:25] info: [twx-studio:initializer] ThingWorxStudio dir:  C:\Users\Chernyavskiy\Documents\ThingWorxStudio , home dir: C:\Users\Chernyavskiy\Documents
[11/19/2017 08:02:26] ar-extension version 8.1.1 (1.19.750)
[11/19/2017 08:02:26] info: [twx-studio:index] Studio Ready: listening on 127.0.0.1:3000
[11/19/2017 08:02:28]  [0mGET /%7B%7B::projectType.imgPath%7D%7D  [32m200  [0m3.310 ms - 2216 [0m
[11/19/2017 08:02:28]  [0mGET /%7B%7B::view.imgPath%7D%7D  [32m200  [0m2.788 ms - 2216 [0m
[11/19/2017 08:02:28]  [0mGET /%7B%7B$root.currentProject.thingServerQRCode%7D%7D  [32m200  [0m2.908 ms - 2216 [0m
[11/19/2017 08:02:28]  [0mGET /%7B%7BviewType.imgPath%7D%7D  [32m200  [0m2.989 ms - 2216 [0m
[11/19/2017 08:02:28]  [0mGET /images/%7B%7B::w.name%7D%7D.png  [32m200  [0m3.006 ms - 2216 [0m
[11/19/2017 08:02:45] error: [twx-studio:auto_configure] 500 'Unable to retrieve service details.' Error: tunneling socket could not be established, cause=connect ECONNREFUSED 127.0.0.1:80
[11/19/2017 08:02:45]     at ClientRequest.onError (C:\Users\Chernyavskiy\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\node_modules\tunnel-agent\index.js:177:17)
[11/19/2017 08:02:45]     at Object.onceWrapper (events.js:316:30)
[11/19/2017 08:02:45]     at emitOne (events.js:115:13)
[11/19/2017 08:02:45]     at ClientRequest.emit (events.js:210:7)
[11/19/2017 08:02:45]     at Socket.socketErrorListener (_http_client.js:385:9)
[11/19/2017 08:02:45]     at Socket.emit (events.js:210:7)
[11/19/2017 08:02:45]     at emitErrorNT (internal/streams/destroy.js:64:8)
[11/19/2017 08:02:45]     at _combinedTickCallback (internal/process/next_tick.js:138:11)
[11/19/2017 08:02:45]     at process._tickDomainCallback (internal/process/next_tick.js:218:9)
[11/19/2017 08:02:45]  [0mGET /api/autoConfigure  [31m500  [0m1031.224 ms - 58 [0m
[11/19/2017 08:02:45] error: [twx-studio:index] unhandledRejection Unable to retrieve service details.
[11/19/2017 08:02:46] info: [twx-studio:logging] Overwriting env DEBUG  info:ves-publish*,error:ves-publish*,undefined  with new value
[11/19/2017 08:02:46] info: [twx-studio:logging] Debug logging disabled
When I connected from an outside network, I could log in.
What are the network requirements for ThingWorx Studio?
Best regards,
Vladimir
Volodymyr Chernyavskiy​: From the error message it seems to be network configuration issues. I believe your organization network is blocking port which needs access during auto configuration.
Request  you to refer our existing Knowledge based article for details on resolution.
ThingWorx Studio Failed Connection Issues
Hope it helps.
-Durgesh
Hope it helps.
-Durgesh
