Best answer by Jimwang
@Sola , Although I see some NoSuchFiles errors in <UserProfile>/VuforiaStudio\Projects, it seems to me that it is a trial system, and the trial Experience Service server "https://7eddb008e5705819.studio-trial.vuforia.io/ExperienceService" is expired, that is the reason you could not publish the experiences.
If you have non-trial Vuforia, you can test it on the platform again.
@Sola
It seems that this is a duplicate one. If not, could you reproduce it and provide the complete Studio log here?
Typically the Studio.log is under <User Profile>\Documents\VuforiaStudio
Sola1-VisitorAuthor
I did import it from another profile but I did something similar before and I could still publish it with no problem, I have attached the complete log below.
Jimwang16-PearlAnswer
