Reduce PVZ file size
  • September 21, 2022
  • 2878 views
Sorry for the noob question.
Is there a way we can reduce PVZ File size?
I've been working on a project with an original c3di file of about 1gb.
I already reduced the drawing to what I only need in my AR Experience but the pvz size is still about 400MB.
When I try to upload it with Optimizer, I can't get through as it will be interrupted for reasons I don't know.
Then in my experience I need to upload 4-5 files of about the same size.
I am using Vuforia Studio, Creo View and Creo Illustrate only.
I checked that using Creo Parametric there's shrinkwrap or something similar but in the software im using there's none. I also dont have the MCAD Adapter.
Hope there are ways.
Thanks in advance for those who can help. Cheers!
Have tried to run the commands manually from the CAD tool shell?
Example how to do can be found here: https://community.ptc.com/t5/Vuforia-Studio/Optimize-PVZ-before/m-p/649769#M7582
At least you will be able to see any error messages
/Per
Per Lönnehed
Fellow
+46-706-740 668
plonnehed@ptc.com
ptc.com
upload_-aW1hZ2UwMDIucG5n-3466277002753626312..pngupload_-aW1hZ2UwMDMucG5n-2510311459225555729..pngupload_-aW1hZ2UwMDQucG5n-6218219724779075155..pngupload_-aW1hZ2UwMDUucG5n-11377508816803424..pngupload_-aW1hZ2UwMDYucG5n-3667646701339723111..png
Adrian_G.10-MarbleAuthor
Hi @pandersson ,
Thanks for the reply.
Actually I tried this one too.
When I tried to follow the commands, it says no input files given.
Im not sure what went wrong or where did I go wrong.
I have 4 batch commands there I think.
To call my optimizer: (am I right?)
C:\Users\KM64741\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\@ptc\cad-import-filters\import_filters\bin\pvsoptimize.exe
To configure rcp files:
-r C:\Users\KM64741\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\@ptc\cad-import-filters\import_filters\recipe\pvsoptimize_low.rcp
For the location of the output:
-vc1 -p C:\Users\KM64741\Desktop\ForAR
For the input:
-o,C:\Users\KM64741\Desktop\ForAR\PC950OutsideView.pvz
is this correct??
Hi @Adrian_G. ,
I think ,when you did not explicitly specified the location - there are the following candidates  of locations:
- current directory where you started the Windows prompt CMD
- the source directory where is the original pvz file
Please, let me know when you could not find your optimized file , So then , I will check it on my Installation. but in this case, please provide  an example how did you call it (the string called in the cmd box - to be sure that I will test the same case) , thanks
