ThingWorx project upgrade error
  • May 9, 2018
  • 1215 views
I am getting error
[twx-studio:upgrade:Test] Error building project TypeError: preservetime is not a function at Object.copySrc (C:\Users\Deepesh\Documents\ThingWorxStudio\Projects\Test\gulp-shared.js:105:11) at Object.onbuild (C:\Users\Deepesh\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\node_modules\ves-ar-extension\server\tasks\build.js:26:32) at C:\Users\Deepesh\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\utils\projectHelper.js:371:48 at at process._tickDomainCallback (internal/process/next_tick.js:228:7)
When i upgraded my Thingworx project from version 1.5.0 to 8.2.2.
Can anyone help me with the possible cause for the error. And how to fix it?
Hi @Deepesh,
Please review the steps given in the below article and let us know if it helped to resolve the issue:
Artilce: https://www.ptc.com/en/support/article?n=CS259459
Deepesh1-VisitorAuthor
Hi @ytella,
Thanks for the response.
I did follow the mentioned steps but it didn't worked out.
The project was build on ThingWorx Studio 1.5.0. I did a fresh install on new machine and imported the project folder of ThingWorx 1.5.0 to ThingWorx Studio 8.2.2 where it was incremental upgrade on project files as i could see in the logs. But it failed on the final project build with mentioned error.
Hi @Deepesh,
Thanks for the update! Could you please share the twx_Studio log to debug the issue.
