Toggling of Shaders not working
  • February 16, 2021
  • 2 replies
  • 6402 views
Since the update, I have come across a lot of issues. Recently I was checking the toggling of shaders on model items, it doesn't toggle anymore. Also the orientation of model items are getting inverted.
Best answer by sebben
You can apply the "Default" shader by using:
$scope.view.wdg["model-1"].shader = "Default";
Same thing is happening with me too. Can anyone help me in this
could you explain in more details how you are trying to toggle the shader?
Thanks.
Let me explain with the help of an example,
I have two buttons, with one I am applying X Ray shader to model items. And with the other, I am removing/ undoing the X Ray Shader to the same model items. Before the update this toggling of shaders to model items  were working fine but since the update, the shaders get applied to model items but now they don't get removed unless another shader is applied to those model items. Is this an issue with the latest update.
8-Gravel
July 13, 2021
Even after applying the above code to the model item, shader is not getting reset.
