Vuforia view craches when using model target on 20mb pvz.file
As the title says vuforia view craches 2 second after I press the link to view the experience. This does not happen when I use a .pvz file that only is 3,5mb. Also the same 20mb pvz file works fine when using a spatial target or ThingMark.
The experience does not contain anything besides the model target.
Is there a max size to the pvz files used when using model target or is it a bug?
