What's New in Vuforia Studio 8.3.3
  • August 24, 2018
  • 5 replies
  • 8177 views
Vuforia Studio
  • Support for Spanish locale
  • Model sequences can be applied at design time
  • Bug fixes and minor improvements
Vuforia View
  • HoloLens:
    • Support for model-based tracking
    • Support for sequence animations created with Creo Illustrate 4.1 and later
  • Windows:
    • Support for spatial tracking
      • NOTE: Currently only the Microsoft Surface Book and Microsoft Surface Pro 4 are supported.
Experience Service (On-Premises)
  • Support for Spanish locale for the installer
  • Model target generation as a service (Beta)
18-Opal
August 27, 2018
Thanks, Tara. Can you give a little more information about this item:
It's not clear to me what that means, or when I would want to use it (or not). Thanks.
--Clay
As best i can tell there is now a checkbox under "Sequence" for Model widget items that says "Apply sequence at design time" If you check this the component visibility defined in the sequence is applied in the design 3D view, but not any animation steps in the sequence.
All my sequences start with the parts in the same position so i'm not sure if you had Step 0 defined with parts in a different position maybe the parts in design would go to that location when you picked that sequence?
This seems like it will be helpful for checking imports from Illustrate and possibly for when trying to pick internal parts to apply ModelItems too. Now if we could just get grouping and hiding of objects in the "Tree" like in Creo...
18-Opal
August 27, 2018
Also, a big THANK YOU to the dev team for getting Hololens support for newer versions of Creo Illustrate! Smiley Very Happy
@tmccombie Is the grouping of ModelItems under the parent Model new? This pretty big news on the large experience organization front!
tmccombie21-Topaz IAuthor
@jmikesell yes, this is a new improvement to the 3D container.
@tmccombie it seems that with the new 3D container you can no longer drag modelItems in the tree to reorder them. Not drag them out of the 3D container but just reorder in the container. This is a loss of functionality that should be fixed.
Hi Tara,
I want to know about the following.
 thanks,
Preeti
It seems like after this update my Windows laptop does will not show me the camera anymore. I just get a black background.
I have tried resetting the app and uninstalling it but the problem persists. Any idea how to fix this? Or if there will be an update shortly to fix this issue?
Is anyone else experiencing an issue with Windows devices not showing the camera? We are having an issue as we are needing to demonstrate Vuforia from a Windows device.
I just tried an experience on a Surface Pro 3 with View 83.3.478.0 and it worked without problems.
