What's New in Vuforia Studio 8.3.3
  • August 24, 2018
  • 5 replies
  • 8177 views
Vuforia Studio
  • Support for Spanish locale
  • Model sequences can be applied at design time
  • Bug fixes and minor improvements
Vuforia View
  • HoloLens:
    • Support for model-based tracking
    • Support for sequence animations created with Creo Illustrate 4.1 and later
  • Windows:
    • Support for spatial tracking
      • NOTE: Currently only the Microsoft Surface Book and Microsoft Surface Pro 4 are supported.
Experience Service (On-Premises)
  • Support for Spanish locale for the installer
  • Model target generation as a service (Beta)
18-Opal
August 27, 2018
Thanks, Tara. Can you give a little more information about this item:
It's not clear to me what that means, or when I would want to use it (or not). Thanks.
--Clay
tmccombie21-Topaz IAuthor
Hi Clay,
This feature allows you to view your model during design as it will show in the experience based on the sequence selected. It is a check box found under the sequence selector for the model.
 model loaded into Studiomodel loaded into Studiosequence applied at design timesequence applied at design time
Hope this helps!
18-Opal
August 27, 2018
It does, thanks!
18-Opal
August 27, 2018
Also, a big THANK YOU to the dev team for getting Hololens support for newer versions of Creo Illustrate! Smiley Very Happy
@tmccombie Is the grouping of ModelItems under the parent Model new? This pretty big news on the large experience organization front!
@tmccombie The new grouping is really great, but it seems that now we've lost some capabilities:
  1. I can't select a modelitem in the 3D view any more.
  2. When I select a modelitem in the project tree, it doesn't highlight in the 3D view.
This seems to happen once I go out of a project and come back in after creating a modelitem and it only seems to apply to HoloLens experiences.
I have confirmed with our development team that this is a known bug and will be fixed in the upcoming 8.3.4 release.
Hi Tara,
I want to know about the following.
 thanks,
Preeti
It seems like after this update my Windows laptop does will not show me the camera anymore. I just get a black background.
I have tried resetting the app and uninstalling it but the problem persists. Any idea how to fix this? Or if there will be an update shortly to fix this issue?
Is anyone else experiencing an issue with Windows devices not showing the camera? We are having an issue as we are needing to demonstrate Vuforia from a Windows device.
I just tried an experience on a Surface Pro 3 with View 83.3.478.0 and it worked without problems.
