gauge up date
  • September 18, 2017
  • 2606 views
I created a AR using CAR properties , and I put Engine Temp on a gauge , but after publication I didn`t have any value on virtual  gauge
I need a gauge that up date dynamicaly the value showed on the gauge
Best answer by mduarte
hi
I found the documentation and fix the problem,
Thanks for your attention
Mauro
Mauro Duarte​ : I am not clear on your exact issue/request. Is it that you are binding some data to the 3D Gauge and it is not showing the values provided or you have requirement to bind dynamic data to the gauge widget . Please clarify.
-Durgesh
mduarte1-VisitorAuthorAnswer
hi
Mauro
mduarte how do yo make dinamyc gauge?  if you have a more information for the topic i appreciate for the answer
