how to get stepsname/sequencenames/stepdescription from pvz file (saved in repository in thingworx)
  • September 19, 2024
  • 3 replies
  • 1063 views
Hello Community,
         I have installed the extension  CreoViewRWExtension in thingworx platform and it does show a lot of information about pvz file in thingworx but i am unable to get the stepsname and stepsdescription. It does shows a sequence names though and a lot of other stuff. here is the extension link:
EXTENSION
https://github.com/mvonhasselbach/CreoViewRWExtension/tree/master
I have already raised an issue in the community the link is as below for further clearance:-
THINGWORX QUERY
https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-extension-to-compress-videos/m-p/972096#
Please let me know how can i achieve that.
MA873117416-PearlAuthor
@RolandRaytchev  do you have please any idea about it? My pvz file i have saved in file repository in thingworx and i just want info now about step name, sequence name from it. this extension which i have installed is so good but it does not show me this info there.
Catalina
Community Moderator
September 24, 2024
Hi @MA8731174,
Thank you for your question!
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina | PTC Community Moderator
I don't believe the extension provides that info. You can access the pvz in the repo and unzip and look for pvi's and look inside for
galaxy_3di:sequence
