how to show the sequence on button rather than showing using squence list.
  • January 3, 2020
  • 2911 views
$scope.setSequenceList = function(){
$scope.app.params.sequencelist = [
"display":"FAN SERVICE",
"value":"app/resources/Uploaded/l-Creo 3D - FAN SERVICE.pvi"
"display":"FAN REPAIR",
"value":"app/resources/Uploaded/l-Creo 3D - FAN REPAIR.pvi"
"display":"HARNESS REPLACE",
"value":"app/resources/Uploaded/l-Creo 3D - HARNESS REPLACE.pvi"
$scope.setSequenceList();
$scope.selectSequence = function(){
console.log($scope.app);
if($scope.app.view.RepairSequence.wdg["sequence-select"].value){
$scope.app.view.RepairSequence.wdg["bottom-nav-grid"].visible = true;
$scope.app.view.RepairSequence.wdg["select-popup"].visible = false;
else {
$scope.app.view.RepairSequence.wdg["bottom-nav-grid"].visible = false;
$scope.app.view.RepairSequence.wdg["select-popup"].visible = true;
This is the code i am using to show the sequence through sequnce select list.
Now i need to show each step on different button individually
Best answer by Swapnil_More
Hello Manoj,
Please change model ID and Step number so you can use this code.
Please find below code and read it carefully so you can get my point.
$scope.sequence1 = function () {
$scope.$applyAsync(()=>{angular.element(document.getElementById('Model-ID')).scope().reset();});
//does not work synchronously
//delay of .5 sec to be sure that all action are done
$timeout(function () {
$scope.$applyAsync(()=>{$scope.setWidgetProp('model-1', 'currentStep', your_step_number);});
//further delay for a 0.5 sec to be sure that the step is set and then play
$timeout(function () {$scope.$root.$broadcast('app.view["Home"].wdg["model-1"].svc.play'); }, 500);
}, 500);
Hello Manoj,
As per your question, you want to add each step/sequence on different button
so please find below code for same.
 Please change Model Id & Step No. for same.
$scope.$applyAsync(()=>{angular.element(document.getElementById('model-1')).scope().reset();});
$scope.$applyAsync(()=>{$scope.setWidgetProp('model-1', 'currentStep', 2);});
}, 500);
Hello Swapnil,
Thanks for replying.
there is an issue encountered ,using this code i have to place three different model and then show the three sequence.
I just want to place one model and then show the three sequence in three different buttons.
Regards
Manoj
Hello Swapnil,
Thanks For Replying on my query. As the code which you had shared has worked and i am able to show threedifferent sequence on three different buttons.
COde which i have used
$scope.sequence2 = function () {
$scope.app.params.training_button = false;
$scope.app.params.configuration_button= false;
$scope.view.wdg['Repair_sequence']['sequence'] = 'app/resources/Uploaded/l-Creo 3D - 1.pvi';
//reset it only if you want to interrupt a playing step otherwise is not necessarily
$scope.$applyAsync(()=>{angular.element(document.getElementById('Repair_sequence')).scope().reset();});
//$scope.view.wdg['Repair_sequence']['currentStep']=1;
$scope.$applyAsync(()=>{$scope.setWidgetProp('Repair_sequence', 'currentStep', 1);});
$timeout(function () {$scope.$root.$broadcast('app.view["RepairSequence"].wdg["Repair_sequence"].svc.play'); }, 500);
}, 500);
$scope.sequence3 = function () {
$scope.view.wdg['Repair_sequence']['sequence'] = 'app/resources/Uploaded/l-Creo 3D - 2.pvi';
//$scope.view.wdg['Repair_sequence']['currentStep']=2;
$scope.$applyAsync(()=>{$scope.setWidgetProp('Repair_sequence', 'currentStep', 2);});
}, 500);
Thanks & Regards
Manoj Pandey.
