infoboard (gauge); label - line break
  • February 1, 2021
  • 3103 views
Hi everyone,
i want to make kind of a infoboard (see attached picture), where i see the step names of my sequence and below an additional info-text.
I started to make a gauge with this image
and added the step-names of my sequence to this gauge by this code:
var labelId = "gauge_steps";
$scope.$on('newStep', function(evt, arg) {
      $scope.setWidgetProp( labelId, "text", arg);
This works fine and my stepnames are shown in the top-left of my gauge-image.
Now i want to add some additional info text under the stepnames. I was thinking about just placing a 3D-label and controlling the text with the steps of my sequence.
How do I make a line break in a label to add more infotext and how do I align the text to the left?
The reason I added so much information for this simple question was, because I am also wondering if there is another (more elegant) way to make such an "infoboard".
Thanks for any kind of help!
Best answer by RolandRaytchev
Hello @DF_9703795 ,
so far I know a 3Dlabel will not work for  a multiline text. So, it will ignore and write it into one line.
possible is:
- to create a customer widget- this is advance option - requires some deep experience
- more simple way (requires some programming work) is to have for each line a 3Dlabel widget and to split the text via javascrpt the text in different lines and then set the line to the 3D label widgets. For all line where the widget does not contain text thy could be set to invisible.
- another option I already used is to use instead a 3DImage and to generate a dynamic SVG file and to set to the 3DImage widget. You can see this  post:"Display SVG as 3D Image on Hololens"
Here is an existing post for related issue "3DLabel Wrap Text"
Hello @DF_9703795 ,
possible is:
Thanks for your reply!
I am currently trying to make the "simple" solution, with the 3D-Label.
I am struggling to change the text of a label with the the currentStep. So for example:
if($scope.view.wdg['model-1']['currentStep'] == 1){
$scope.view.wdg['label_SubtextL1'].text = 'Info for step1';
this workes good when i set it into the "playStarted" event of the model-1, but not good when i use my "skip" and "go forward" buttons.
With $watch and switch:
$scope.$watch(
 'view.wdg["model-1"].currentStep', function(val) {
 switch (val) {
 case 1:
 $scope.view.wdg['label-1'].text = "1. First description";
 break;
 case 2:
 $scope.view.wdg['label-1'].text = "2. Second description";
 break;
 case 3:
 $scope.view.wdg['label-1'].text = "3. Third description";
 break;
 default:
 break;
Hope this helps.
