11-Garnet
October 5, 2020
Disable delete permission in Classification Administration
  • October 5, 2020
  • 2 replies
  • 4105 views
I want to restrict some of the users from deleting classification node in Classification Administration, they should have access only to view the nodes. Please let me know the feasibility.
Available article pertaining to the mentioned requirement:
https://www.ptc.com/en/support/article/CS232933
Thanks in advance.
Sha
Best answer by ScottMorris
As far as I know, being a Classification Admin is like being a Windchill Admin. Either you are or you aren't. There is no built-in delineation of what actions are available and what actions are not. I get what you are asking for, the ability to make someone an admin, but not have to give them full authority. Perfect case for someone you want to do maintenance like update images, but not edit the hierarchy.
This should be added as a new Windchill Idea if it hasn't been already.
@hsha1102 If they are not in the Classification Administrators, then they shouldn't even see that tab to be able to get to the tree structure to delete from there.  I just checked one of my users Windchill.  If that is the case, then there is a bug or something is set up incorrectly.  Or are you meaning at the wtPart level and removing a node from a specific wtPart?
Edit after rereading your post I have another question. If users can see the nodes from the Classification Explorer, why do they need to see them from Classification Administration if they are not to have admin functions?
hsha110211-GarnetAuthor
11-Garnet
October 5, 2020
Hello Brian,
No, the users are added as Classification Administrators hence they have access to delete the nodes. I want a specific set of users to not have the delete option but only view access.
No, I do not mean in part level attribute.
I had reread it and edited my last post.  Why do they need to be in that area if you can see the nodes from the Classification Explorer?  Is there a reason they need to see it at the Admin level?
