Dynamically populate Resource Pool: Workflow Task
  • February 16, 2023
  • 2 replies
  • 2628 views
I have a requirement where I need to populate the Resource pool of a workflow task based on an attribute, say location, selected by the user at the time of creating a Change Notice. For example, if the user has selected the location as Spain, the resource pool of a set-up participant task should be updated with Spain group for a role. Requesting you to provide some info on the feasibility to implement the same.
Sha
This is possible with customization.  @d_graham built something for me that does something very similar.
HelesicPetr
Hi @Sha11
There are many ways how to achieve what you need.
One option is to create a tasks with your specific participant teams one task for one team
create a conditional route where simple java code checks a value of the parameter and goes to the correct task with right team based on the value.
also there can be other way how to do it.
PetrH
Sha1114-AlexandriteAuthor
@HelesicPetr ,
The way that you mentioned will not work for me, I have multiple teams for various tasks, if I am to follow that way I would have to introduce 70 workflow tasks. Looking for some way to customize the same.
18-Opal
February 20, 2023
Yes, I have done this before.  I just look into my toolbox to refresh my memory.
It's doable, for sure.
You can both add and remove resource pools on the fly using APIs.
The request I had several years ago was to set resource pool based on an attribute value in the PBO.
It's tricky for sure, but doable.
