Hello, I am new to PTC Windchill (Quality Solutions). I am currently using ver 11.0. I need assistance in inserting new lists into a form and need to know how to delete, modify forms. Thank you
  • April 7, 2016
  • 1704 views
Hello, I am new to PTC Windchill (Quality Solutions).  I am not sure if this is right forum.  We are currently using ver 11.0 and am finding the on-line documentation less than user friendly. I need basic starter information - like assistance in inserting new lists into a form and need to know how to delete, modify forms.  Are there better instructions somewhere? Thank you
Instructions are either in the html package installed whenever you install application, or in a pdf file that can be found in the PTC portal (Reference Guide).
To edit or remove forms, proceed through Navigation Panel, selecting the form to modify, right click and select edit or delete. To add, proceed creating a new file from type "Report Form" or "table",...
Lists are a little bit tricky, however is not a huge task requiring more detailed explanation
bmadrigal1-VisitorAuthor
Thank you for the reply and help. I appreciate it.
Can you tell me how to delete a field I might have added and now want to remove?
Deleting a field depends where are you working with, but is an easy task.
If you are desingning a report, just click on the field, this will be highlighted with severa little squares in the corners and in the borders, then click "Delete".
If you're in a table design, in the table list, select the field and press delete.
More details can be found also on the "Getting Started Guide" that can be found in PTC Support page.
Hope this helps
