How to create a WfAssignmentEventAudit object
  • December 13, 2024
  • 3 replies
  • 695 views
Version: Windchill Below 11.0
Use Case: I used a api below this scentence to complete a WfAssignedActivity object ,but it did not created a related WfAssignmentEventAudit object,why ? wt.workflow.engine.WfEngineHelper.service.changeState(assignedActivity, WfTransition.COMPLETE);
Description:
wt.workflow.engine.WfEngineHelper.service.changeState(assignedActivity, WfTransition.COMPLETE);</span>
HelesicPetr
Hello @XL_9673631
I would recommend to check how to enable OOTB Audit events
CS208355 - How to enable Security Audit Reporting for Out Of The Box events
also check
CS319164 - [Knowledge Hub] Windchill PLM - Security Audit Reporting
OOTB the WfAssigmentEventAudit is not set to be logged so you have to turn it on.
PetrH
joe_morton
18-Opal
18-Opal
December 17, 2024
I think the issue is that the Event Audit is optional. In the normal workflow editor, you can select whether or not to "record voting"
Per https://www.ptc.com/en/support/article/CS234435?source=search "There is no supported API to create resulting voting events or add comments".
HelesicPetr
Hi @joe_morton
I was sure that he is talking about a Security Audit Reporting 😄 .I didn't check it
Voting, if the task is just completed, then the voting is not recorded because there is no voting.
 If you complete the Task by API then you have to create the WfAssignmentEventAudit by code and write the vote option
and yes, there is no supported api to do so, but you can do it.
PetrH
Community Moderator
January 10, 2025
Hi @XL_9673631,
Anurag
