6-Contributor
May 8, 2023
How to remove blank space in Target State for resulting object in WC12
  • May 8, 2023
  • 3 replies
  • 3042 views
Hi ,
In WC12 for every resulting object the default target state is blank How we can able to remove that or Is there any way to disable it?
@HelesicPetr
Best answer by avillanueva
You want it to say "Change" as the default?
avillanueva
23-Emerald I
23-Emerald I
May 8, 2023
6-Contributor
May 8, 2023
Hi @avillanueva ,
Yes I want change as default target state.
avillanueva
23-Emerald I
23-Emerald I
May 8, 2023
Check your lifecycle state for those resulting items. Make sure that "Change" has a state checked for it. You will have to update lifecycles for existing items to pick this up.
6-Contributor
May 8, 2023
@avillanueva  But In WC12 the default target state is blank so How can we remove that
avillanueva
23-Emerald I
23-Emerald I
May 8, 2023
I do not think that this is default so to speak. You need to setup your lifecycles to have that checked to tell it what state you want to move to when objected are completed by a Change Notice. Defaults targets are Change and Obsolescence.  In mine, I do not use Obsolescence so since there is only 1, it always defaults to "Change" which is mapped to Released.
HelesicPetr
Hi @BA_10670508
Have you tried to set a type and attribute default value?
PetrH
3-Newcomer
August 21, 2024
Hi @HelesicPetr ,
After configuring the default value in change record, still the blank value is auto selected in release target state.
@BA_10670508 @avillanueva - Can you please suggest if you got any solution on the same.
Thanks and Best Regards
Nagaraj Nadagouda
We need to set default in two places to work:
one in Transitions and other is Change Transition RB
