6-Contributor
May 8, 2023
How to remove blank space in Target State for resulting object in WC12
  • May 8, 2023
  • 3 replies
  • 3042 views
Hi ,
In WC12 for every resulting object the default target state is blank How we can able to remove that or Is there any way to disable it?
@HelesicPetr
Best answer by avillanueva
You want it to say "Change" as the default?
avillanueva
23-Emerald I
23-Emerald I
May 8, 2023
6-Contributor
May 8, 2023
Hi @avillanueva ,
Yes I want change as default target state.
avillanueva
23-Emerald I
23-Emerald I
May 8, 2023
Check your lifecycle state for those resulting items. Make sure that "Change" has a state checked for it. You will have to update lifecycles for existing items to pick this up.
6-Contributor
May 8, 2023
@avillanueva  But In WC12 the default target state is blank so How can we remove that
6-Contributor
May 8, 2023
Hi @avillanueva ,
Yes it is mapped properly I have enabled Released state from Change but still the default is blank only.
Please check - https://www.ptc.com/en/support/article/CS370326.
Any other option I can do?
HelesicPetr
Hi @BA_10670508
Have you tried to set a type and attribute default value?
PetrH
3-Newcomer
August 21, 2024
Hi @HelesicPetr ,
After configuring the default value in change record, still the blank value is auto selected in release target state.
@BA_10670508 @avillanueva - Can you please suggest if you got any solution on the same.
Thanks and Best Regards
Nagaraj Nadagouda
We need to set default in two places to work:
one in Transitions and other is Change Transition RB
