Is there any API to get any object from a given number which is unique.
  • April 25, 2022
  • 4741 views
it should show results of objects, for the given (any unique)number as shown in the advanced search.
Best answer by HelesicPetr
Hi @manoj_dokku2
I don't think so. It is not easy as you think.
The helper has a getPersistable() function where String is input but this string is defined as a type identification and OID it is not object Number
example> OR:wt.part.WTPart:26891877
Also if the advanced search is activated in a explorer, there is full list of searchable types as a parameter in a function. And the function is hardcoded :D.
I can't see simple function there that just search for Numbers.
PetrH
HelesicPetr
Hello @manoj_dokku2
If you define correctly QuerySpec defintion, then you can use
PersistenceHelper.manager.find(QuerySpec QS)
QuerySpec spec = new QuerySpec(WTChangeActivity2Master.class);
spec.appendWhere(new SearchCondition(WTChangeActivity2Master.class,
WTChangeActivity2Master.NUMBER, SearchCondition.EQUAL, number), new int[]{0});
QueryResult qr = PersistenceHelper.manager.find((StatementSpec) spec);
if (qr.hasMoreElements())
I don't know another universal API.
I would define all types if I need to search all objects.
PetrH
Thanks for the reply @HelesicPetr , I'm looking for generic query which will give the object if we pass the number(any) from Windchill.
HelesicPetr
Hello @Ajit_Kulkarni
I'm not sure if this object has a number clasification that can be return by query
The object has just three methods that can be returned
getDisplayIdentity ()
getDisplayType ()
getDisplayIdentifier()
I will check.
PetrH
