Version: Windchill 13.0
Use Case: I've created a first version of a project that uses the Windchill API to export a .pdf file from a .drw using this URI: /Windchill/servlet/odata/v3/CADDocumentMgmt/CADDocuments('OR:wt.epm.EPMDocument:201731655')/Representations EPMDocument:201731655 was known previously.
Description:
Is there a way to retrieve a list of all EPMDocument (only .drw ones) versus Drawing Numbers? I am asking it because I need to generate .pdfs from .dwgs in batches.
I've got a solution (dunno if it's the smartest one but...)
