New WTPart, Property Display (Unallocable)
  • September 29, 2024
  • 1070 views
Version: Windchill 12.0
Use Case: I have set the 'Product Phase Identification' attribute to 'read-only' and set it to the default value. I need to make the 'Product Phase Identification' attribute display the default value instead of (unassigned) on the New and Edit pages. How do I configure it.
Description:
joe_morton
18-Opal
18-Opal
September 30, 2024
HelesicPetr
Hi @joe_morton
If you use the immutable element, then the value can not be changed.
PetrH
joe_morton
18-Opal
18-Opal
October 1, 2024
@HelesicPetr
Do you mean adding the constraint Immutable, or something else?
Adding the immutable constraint causes the field to show "(Unassignable)" instead of showing the default value. I think that's what he's trying to avoid. I'm using 12.0.2.18, so maybe it's different in other versions.
