Version: Windchill 12.0
Use Case: I have set the 'Product Phase Identification' attribute to 'read-only' and set it to the default value. I need to make the 'Product Phase Identification' attribute display the default value instead of (unassigned) on the New and Edit pages. How do I configure it.
Description:
Maybe this method?
https://www.ptc.com/en/support/article/CS412295?source=search
Do you mean adding the constraint Immutable, or something else?
Adding the immutable constraint causes the field to show "(Unassignable)" instead of showing the default value. I think that's what he's trying to avoid. I'm using 12.0.2.18, so maybe it's different in other versions.
hi, The method you provided solved my problem of setting default values, but I still want to address the issue of only displaying Unassignable. I want him to display the default values I set by default
