OData - CompleteWorkitem returns the error "This task cannot be updated..."
  • December 12, 2023
  • 3956 views
Dear all,
I have a question regarding completing the work items. I have a work item which includes a custom EnumeratedType attribute "MySize".
When I try to complete the activity using the OOTB Endpoint from Workflow Domain, I am getting an error that the enumerated type is not supported like below:
"This task cannot be updated.Variable type ext.dropdown.MySize is  not supported."
URL: {{baseUrl}}/WorkItems('{{WorkItemId}}')/PTC.Workflow.CompleteWorkitem
Request Body:
    "AutomateFastTrack"false,
    "UserEventList": ["Yes"],
    "VoteAction""",
    "WorkitemComment""Dummy",
     "Variables":[{
        "Name":"MySize",
        "Value":"Small",
        "TypeName":"ext.dropdown.MySize",
        "DisplayName":"MySize"
Does anybody have a solution / workaround regarding this?
Thanks in advance!
Best answer by HelesicPetr
Hi @xolomon
I can see just only one workaround.
extends existing site, with own custom REST API function that does exactly what you need.
PetrH
HelesicPetr
Hi @xolomon
Be careful if you use display value or the internal value of the enumeration.
I guess that you should use the internal value.
And the question of the day, Is the internal value real;y "Small" ?
PetrH
xolomon14-AlexandriteAuthor
Hi @HelesicPetr,
thanks for the remark, I have been trying with both internal and external values. But unfortunately this is not the main problem.  It seems that OOTB only allows primitive, string and date variables in this area.
Cheeers,
Xolomon
Hi @HelesicPetr and @joe_morton,
thanks for your messages. The example that I have provided was exactly based on the article mentioned by @HelesicPetr for the discussion. The real life example is similar to the example but with customer specific enumeration. I also think that it is a supported customization as the example was provided us by the technical support.
