7-Bedrock
May 22, 2025
Remove Organization Name Info
  • May 22, 2025
  • 2 replies
  • 625 views
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.9
How remove the Organization Name in the Windchill notifications?
I follow the steps of CS312309 but not working
    Catalina
    Community Moderator
    May 29, 2025
    Hi @dmazaira
    Thank you for your question.
    It appears your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
    Best regards,
    Catalina | PTC Community Moderator
    avillanueva
    23-Emerald I
    23-Emerald I
    May 29, 2025
    Can you show or explain what you tried so far? Please post your email template and the result you are getting.
    dmazaira7-BedrockAuthor
    7-Bedrock
    June 2, 2025
    templateMail.jpg The Blue rectangle information it's that I want remove. I modify the NotificationRobot template, but only Apply in new Workflow Template.  It does not work, even if you iterate the workflow Template.  It's not working in the actual workflows process that are running and the new Workflow Process with a workflow Template created before the change..
    avillanueva
    23-Emerald I
    23-Emerald I
    June 10, 2025
    I've done some email modifications but I did not remove that part. I think its added to the template somewhere else.
