Sync Robot : Object Event
Dear Users,
Pls suggest on the clarification I have on the Sync Robot defined in WF's
1. I have modified the robot to use Object even but my Initial and Routing expression needs to wait for the Child / Associated part of PBO. Which mean I need to update the parents state based on the state change happening in child. But if I use Object Event , it listens to the PBO and not the child. Also i doont want to use Class event due to the performance constraint.
Pls suggest if any customisation / ideas is feasible to overcome this .
Srira,
