Unable to add "Reviewer" tab on the "Select Participants" window of a Promotion Request
  • May 24, 2023
  • 3689 views
Hello Everyone,
We are trying to implement a "Staggered" Approval Promotion process in Windchill. Apart from "Approvers", the workflow must also include "Reviewers" to be aware of the objects being promoted, but not need to perform any actions. I have added a couple of "Review" tasks similar to what was available in the OOTB "Two Level" Approval Process. However, even after adding all the necessary participants for the respective "Review Tasks", I am unable to view the "Reviewer" column in the "Select Participants" window of a Promotion Request.
How could I achieve this?
BWorkflowWorkflowNew_Promotion_Request.pngBest Regards,
Irfan
Best answer by HelesicPetr
Hello @MIK_203
I can see that the users are already selected.
This means that configuration in the Preference Management the "Fixed Roles For Promote " is set
If the preference is set then the roles are preselected and you can not change it.
PetrH
HelesicPetr
Hello @MIK_203
Where the "reviewer" role is defined? in which Task? If the "reviewer" role is not used in any task, then it can not be shown in the table
PetrH
MIK_2034-ParticipantAuthor
Hello @HelesicPetr ,
Both "Review Tasks" as you see in the Workflow include the "Reviewer" & "Review Manager" as participants.
Attached a snapshot for reference.
BR, Irfan
Hi @HelesicPetr ,
I checked the Templates folder and since this is a custom WF template, it is only created at an "Org Level" and not at "Site" level.
Also the preference setting you just mentioned includes both the Approver & Reviewer in there.
BR,
Irfan
