Update IBA on ECN
  • July 14, 2025
  • 4 replies
  • 583 views
Hi @HelesicPetr
I am doing one POC.
Requirement is I have to update specific iba on ECN.
Basically we have global iba on ECN and Container and IBA of container having value so now our requirement is we want to copy paste that value on ECN IBA while creating the ECN.
So here can we use OIR or any custom algorithm to achieve this .
reference topic: https://community.ptc.com/t5/Windchill-Customization/OIR-Update-for-IBA-Value/m-p/829884#M2883
HelesicPetr
Hi @VK_1647
I would just recapitulate your requirement>
You have a container (context product/library) with IBA that have some value and you want to copy this value to a new ECN IBA attribute?
If I am right then it is not possible by OIR, but you can achieve it by 1) own DataUtility on a creation Wizard where you can prepopulate your value from the container.
2) Or you can write a code, that will populate the value in your workflow. I do it normally by workflow, it is easier 😄 and user does not care about that attribute.
PetrH
joe_morton
18-Opal
18-Opal
July 18, 2025
If you just need to display the attribute on the ECN, maybe you could try an Alias Attribute: https://www.ptc.com/en/support/article/CS357101?source=search
Fadel
23-Emerald I
July 21, 2025
try to use an alias on ECN with mapping containerReference^wt.pdmlink.PDMLinkProduct~<Global_Attribute_Internal_Name>
This will copy attribute value from product IBA into alias
Buiꓘa
HelesicPetr
Hi @Fadel
If you need to work with this information in a workflow the alias is not the perfect solution
PetrH
Fadel
23-Emerald I
August 6, 2025
Yes you are right we need to to use a REST call from the java using WRSCaller
Buiꓘa
Community Manager
August 12, 2025
Hi @VK_1647,
Anurag
