This is what it says for the property wt.pom.rowPrefetchCount
Default: 20 Synopsis: JDBC driver tuning parameter that specifies the number of rows to pre-fetch when reading result sets. Description: This property can reduce the amount of communication between the method server and the database. However, JDBC drivers may pre-allocate memory for the prefetched rows so there is a potential negative performance impact if the value is too high.
