Can you provide screen shots? Do you think there is an error with CPS 5 or was this just something that happened in installation? Sounds like you are looking to revert back to 13.0.2.2 or CPS 2. Not sure that is possible unless you roll back to a previous backup. Was this CPS just applied?
1. The follow screen shots windchill 13.0.2.5, show garbled characters and can't remove the OOTB menus.
2. The follow screen shot windchill 13.0.2.2, no garbled characters and no extension menus. so I think it's ok.
Recommend opening a case with PTC. Sounds like a bug on their end.
