Workitem Input Attribute
  • October 25, 2022
  • 7417 views
I would like to add some inputs to my promotion request approve task.  There are comment inputs and vote inputs.... but I wanted to add a could of boolean attributes (radio buttons would be nice) for common reasons for rework.  Then, I can collect report data about why Promotion requests are being sent back for rework.
  • Missing Dims
  • Notes
  • GD&T
  • Design Issue
Stuff like that.
I thought I saw an article that says it's not possible but want to ask the community if they think otherwise or have an alternative solution.
The referenced buzz kill...
https://www.ptc.com/en/support/article/CS310508
Best answer by avillanueva
yep
avillanueva
23-Emerald I
23-Emerald I
October 25, 2022
I am not sure that article means what we think it means. I just created a workflow with two boolean attributes and tested it. Displays like this:
You should be able to create a variable in the workflow and also in the task to gather inputs. Then you can write logic around it. Am I missing something? Seems pretty OOTB.
So I can definitely do it in the workflow... I know how to get user input variables in there... and even pass them to the task.  But... That screen shot you have... is that from a task?  The user would have to input that in the task.
HelesicPetr
Hi @ChiselnMallet1
If you set the attribute it is generally shown in the input of the task. In my case
Boolean CheckParams
I just set the parameter as required
PetrH
