error occurs when creating a new product using a custom template
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS13
Explanation:
An error occurs when creating a new product using a custom template.
I checked the contents of the rule name (rule defined by TypeBasedRule) pointed out by the error referring to the article (CS34313, CS45247).
As a result, I found that <AttrConstraint> is inside the <AttrConstraint> tag.
Here are the errors that I faced
Method server log:
wt.rule.init [userid] - org.xml.sax.SAXParseException; lineNumber: 100; columnNumber: 37; The content of element type "AttrConstraint" must match "(Arg|Attr|Value|VarRef)*".(wt.rule.ruleResource/150)com.ptc.core.meta.common.CorrectableException: [rule name] Initial Value The XML specification for the rule is incorrect or invalid.
Popup message:
warning:
Question:
1.Is it correct to understand that this error occurs when <AttrConstraint> tags exist within <AttrConstraint> tags as described?
2.Is there any impact if I put the <AttrConstraint> out to fix the error?
3.There is "lineNumber: 100; columnNumber: 37;" in the method server-side log, but is this the number of XML rows and columns that are causing the error?
Also, where is the 100th line from?
Note:
This post was created using Google Translate, so error messages, etc. may not be accurate.
