I need a filter query to get json only if have WcControlledBOM attribute in every Part Json
  • July 3, 2024
  • 0 replies
  • 620 views
'ABC' part attribute is a boolean type. It is not present in every json if it not having true/false value. So I couldnt use this attribute in $select query to minimise the execution time.
Instead of using 'ABC' Attribute in select query, I need a filter query to get json only if have WcControlledBOM attribute in every Part Json
