Thingworx username case sensitive issue
  • June 29, 2022
  • 3790 views
We have Thingworx Navigate platform where we have deployed 5 apps. We are using Windchill authentication for logging into Thingworx platform. There are two apps which requires manual access and rest of the apps are available for all the users.
We are facing issue when user tries to login with different combinations of uppercase and lower case letters which in turns create 5 different username in Thingworx platform.
Windchill does not have this issue.
What are the ways we can prevent these situation.
Best answer by schauvelin
This is work to spec for TWX : https://www.ptc.com/en/support/article/cs259466
As far a I know you can't change the behavior except by using SSO authentication.
Kind regards.
Kind regards.
Is there any workaround suggested to clean up this mess? We will end up with multiple versions of same user. This may be a licensing issue as well.
Preeti
As far as I know there is no workaround about that.
It's planned for future version but no release announced yet. ref TW-84237.
Kind regards.
