Windchill PLM "Document Management" Tips & Techniques Session Recording (West Coast)
  • August 26, 2021
  • 6 replies
  • 35648 views
Check out this video on Using Document Management in Windchill from PTC Application Engineers
Presenters: Kevin Sergeant (Technical Specialist, Principal) and Ryan Butcher (Technical Specialist, Fellow)
Original Date Presented: August 24, 2021
To dive deeper into the subject, check out Windchill Document Management - PTC University.
Webcast Q&A
Question from CarlCan a custom document be created with company specific parameters?
Answer:  Absolutely.  There are no limitations.
Webcast Q&A
Question from KevinDoes the DTI require a license?
Answer:  DTI is included with any license that allows for Document creation so the Base license and above.
Webcast Q&A
Question from RaghuThis document search is good and much needed.  I really wish Windchill had the ability to search with Creo drawings (notes).
Answer:  You can figure solr to index the text in (Creo Parametric) drawings by setting indexable to true for the DRW format  name.  http://www.ptc.com/cs/help/windchill_hc/wc100_hc/index.jspx?id=WCCG_Serv_DataFormats_AddUpdateDataFormats&action=show.
Question from RaghuConfigure "solr" to index...what is solr?
Answer:  Solr is the indexing capabilities imbedded in Windchill.  It's open source enterprise search platform built on Apache Lucene.
Webcast Q&A
Question from RandeepCan you talk about document retention policy functionality and what tools are available for document redlining?
Answer:  Document Retention Policies - The way we typically recommend this be done via a Life Cycle state.  For example, have a lifecycle state of obsolete.  When that document reaches that state, the access control policies limit access to those documents to only specific admins.  Tools available for redlining - Of course you could still use MS Word markup and edit tracking tools assuming you are using Word.  In Windchill itself, we have the ability to do document relining in CreoView.
Webcast Q&A
Question from TimothyIs there a way to search for files attached in the Attachment panel of an unknown document number's Content tab?
Answer:  We will test and add our results to the Q&A.  There is an alternative approach if you need to index and search for the content of an attachment, you can check it in as a unique controlled document within WC and then you can associate the two documents or create a document structure.  Good news!  We discovered that both primary and secondary content (attachments) can be set to index.  https://support.ptc.com/help/wnc/r12.0.2.0/en/index.html#page/Windchill_Help_Center/WCSysAdminIndexSearchIndexingRules.html
11-Garnet
February 14, 2024
Good day
In the search portion of this presentation, Is the search for document format ie word, pdf etc and the text preview column customized features or n they easily be enabled.
Regards
