修订部件和CAD文档时报错“修订失败:选定项或其关联项可能有更新的版本
Sarah_Rong
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.1.2
同时修订部件和CAD文档时报错“修订失败:选定项或其关联项可能有更新的版本”,单独修订部件没问题
Here are the errors that I faced
Article - ""Revise" of object throws error "New Revision failed. Later revision of either of selected item or its associated item may exist" in Windchill PDMLink": https://www.ptc.com/en/support/article/CS22606
Hello @Sarah_Rong,
It looks like you have a response from a community champion. If it helped to answer your question, please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Done, many thanks!!
