Hi @MJ_10676909
First if you ask to help with OIR you should provide the OIR definition.
It can be miss spelling the lifecycle name or the Lifecycle template is disabled on the specific level. Check all..
Also I would check the type and attribute management if the subtype has set Instantiable to yes it is very important
PetrH
@HelesicPetr : thank you for quick reply ! Lifecycle name is correct and its enabled .
2. Instantiable is Yes.
3. If I change the Lifecycle name its working , I am able to see soft type in dropdown but if i choose the required one its not working . Not able to resolve it .
Mrunali
The trouble can be that Lifecyclie template is on wrong level.
Site/Org/Product/Library. so you need to check lifecycle where is defined, and then check if is enabled.
Also check if the OIR definition level can access to the lifecycle. For example, the Org level definition of IUR can not see product level.
PetrH
Hello MJ_10676909,
I'm Charles from PTC Technical Support in Europe: Was the information provided helpful somehow?
Kind Regards,
Charles Gautier.
