A friend of mine (such thingsonly happen to friends ! ) has set a restriction on a library : WTObject, ALL states, CONFIRMED, deny everything but read.
So I was wondering whether there was a workaround to get back in charge. Would restoring the LDAP from a backup do the trick ? even better is it safe to delete the ldap filescreated after the fatal date ? Or any other way ?
TIA,
Vincent Quesnoit
One more reason that Deny rules are to be used sparingly and only when absolutely required by business cases. Just don't Grant anything but Read, and you probably get what you really need.
That said, the site or org admin user will be able to edit the Policy Domain for the Library via the Policy Admin. Either that user can "fix" things, or they can create an access rule giving the Library Manager user by NAME Full Control over WTObject in the Library, then the manager user can do the "fixing", then the Named User Rule can be removed.
