Assembly Component Find Number Question
We use a lot of family tabled objects here at Steelcase but we don't have a drawing for every instance configuration. We have 1 drawing where all of the geometry of the components are displayed in a view (you could say it's an overloaded view). Therefore all of the components have a drawing balloon with a find number. This find number could be generated by Pro/ENGINEER or manually.
When the instances of the assembly and it's components are checked in to Windchill a BOM of WTParts is created for each instance. Now the Find Numbers need to be assigned for each component of each assembly instance to match the balloons on the drawing. This helps users looking at a drawing identify parts on the BOM. This task can be quite cumbersome as you can imagine.
Does anyone else have this use case?
What are the ways in which you are dealing with Find Numbers for assembly instances to alleviate the cumbersome and error prone entering of this data?
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image002.jpg@01CDADF4.2DFF6470]
