Association Type - Set as Default
  • May 15, 2024
  • 2 replies
  • 1654 views
Hi Guys,
In Windchill we can use the "Target State" to set a lifecycle state at a single shot for all the WT Part rights.
I want the same thing for the association type because whenever tried to associate EPM comes as the owner is the default. I want to change into a contributing image.
Can we control through preference management to set my EPM always in the contributing image? If that means WT Part is Owner Right.
Aj
avillanueva
23-Emerald I
23-Emerald I
May 15, 2024
Thanks for the replay @avillanueva
As per the article, we need to change 3 things in Preference Management Right.
AJ
@avillanueva I am looking for a Part Eccentric Approach Method:
Scenario 1: First we need to create a WT Part first - Without EPM or With EPM we have an option "New CAD Document". [CAD also linked]
Scenario 2: If it's a single component there is no issue with this, but if it's assembly we need to build the structure right.
             How we can approach this - Using the USES TAB to make a strucure or Using the CAD software to make structures. [If I used the USED TAB i can't able to see the CAD structure [While Creation a WT Part enabled the option "New CAD Document". ]
AJ
Community Moderator
May 22, 2024
Hello @Amirtharaj_K
It looks like you have some responses from a community member. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
