Version: Windchill 12.0
Use Case: We are creating problem report from The Thingworx custom application as there are few custom attributes. We are able to create the problem report also the attachment is able to attach in that newly created Problem report. But when we try to open that attachment, it is giving us below error but we are able to see that attachment in attachment tab - "java.nio.file.FileSystemException: \\THSWCQAN1SRVR\pdmlinkvault\pdmlinkvault_Folder_829\00000002098885: The user name or password is incorrect. Nested exception is: java.nio.file.FileSystemException: \\THSWCQAN1SRVR\pdmlinkvault\pdmlinkvault_Folder_829\00000002098885: The user name or password is incorrect."
Description:
Hello Catalina,
I have got the solution. I was passing wrong file id. So it was not able to download or view the file.
Mayur Kulkarni
Hi @MMK_12345
Thank you for your question.
Also, feel free to add any additional information you think might be relevant, for example:
Best regards,
Hello Catalina,
Mayur Kulkarni
