CAD Worker Fails to Start, no worker.log
I have one CAD worker running a machine separate to the Windchill server and have had no issues with it. I wanted to create another temporary one, also on a separate machine, to run for a while as we are putting a lot of new files onto the server that need representations created. I cannot figure out what is causing my issue of Fails to Start.
I have gone through multiple times and checked that everything is setup the same on the temp worker as it is on the production worker. I even removed the production worker and tried just the temp, to see if there was a conflict between them. Temp still threw the error so I recreated the production worker in "Worker Agent Administration" and it connected perfectly and started working on jobs right away.
Every post I have found keeps pointing back to looking at logs on the worker machine, but there are none being created. Where else are there logs on the server that possibly could point to what I have wrong? Permission wise, I have Everyone with Full Control to the "Creoview_Temp" shared folder for jobs to be transferred to.
