Does anyone have workflow code that will check the Affected Objects of a CN to make sure they are at released state before allowing the engineer to complete task? Currently engineering is the only group that can see in work and some engineers don't check before submitting a CN. I would like to add something to the workflow that will automatically check this and throw up an error message if it finds an issue. We are running WC 10.0 M040.
