Can I generate an HTML fragment in DataUtility?
Hello all.
I am trying to display custom HTML fragment inside the OOTB attribute panel. I already created a controller that generates the fragment.
Can I use this controller to substitute attribute value using Data Utility?
As an example I could use com.ptc.carambola.rendering.HTMLComponent to display custom HTML in the attribute:
HTMLComponent hc = new HTMLComponent("<a href='www.google.com'> Goole Link </a>" );
But I need help figuring out how to dynamically generate that HTML.
Windchill R10.1
Any help is very much appreciated.
Vitaliy.
