Can we use WBM Extraction utility in WC to other PLM System Migration
  • May 3, 2023
  • 1414 views
Can we use WBM Extractor to extract data(CAD, parts,Documents) from Windchill system--> put the data into WBM Staging DB--> Export Staging table's data in CSV format--> Load the CSV data into either TeamCenter or 3DExperience. Is this scenario possible?
If not  what options are available to extract data from Windchill and migrate into other major PLM systems like Teamcenter or 3DExperience or AutoDesk?
Best answer by HelesicPetr
Hi @NP_10570407
In my opinion you can use the WBM to extract the data from your system. Then it is up to you what you will do with the data. So yes you can use it.
Someone else can correct me if I am wrong
PetrH
HelesicPetr
Hi @NP_10570407
PetrH
Thanks for the update @HelesicPetr
Yes, it seems possible to extract the metadata and stage it on the WBM staging DB tables. I have verified.
The only challenge I am facing right now is to extract file content from vault locations.
