Cannot save to workspace
I just finished a dry-run migration from Intralink 3.4 to 9.1 and messed something up.
After I check-out and open something in Pro/E and modify it, when I attempt to save, it is being saved to "My Documents" and not the workspace. In fact, the workspace is not even shown as a place to save-to in the Save dialog.
Yet the workspace is available (and the default) when I open a model/drawing.
This is only happening with a regular user (Active Directory).
This is not an issue if I am logged in as wcadmin.
I normally would suspect I messed up on a domain policy, but have not found the possible cause (so far).
And I have been using loadfiles all along for policies, and they have not changed since my initial tests.
Prior migration tests did not have this saving problem.
Any suggestions as to where I should be looking to resolve this?
(maybe a preference setting?)
Gerry
