Hi All,
I want change the ESI transaction status of WTPart in Distribution Target table to failure from currently success.
The success status was loaded manually, so we don't have any transaction xml present.
Any leads/references would be appreciated.
Hi @DKWc
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please provide screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
I'm not sure exactly what you mean by not having the transaction xml, but if you can find the transaction in the ESI Log, you can change the status there.
You can launch the ESI log from Org Utilities.
Thanks Casey,
This approach will only be possible if we have a transaction Id present.
The wtparts are marked manually as succussed for the migrated parts.
