Hello All,
Has anyone experienced a check-in problem with this message: "The object is not checked out and cannot be modified"
The problem is affecting several users so it must be a server issue,but the event viewer does not give an object name so it is
impossible to investigate. The objects upload OK but the check-in also fails from a standalone browser.
The method server log shows this everytime it fails:
2012-01-13 11:39:13,125 INFO [RMI TCP Connection(2840)-10.210.48.3] com.ptc.windchill.uwgm.proesrv.conflict.UwgmMessageSaAdapter - UwgmMessageSaAdapter.processErrorException :: no elements in UwgmErrorException: com.ptc.windchill.uwgm.common.conflict.UwgmErrorException: wt.part.PartException: wt.fc.ModificationNotAllowedException: (wt.vc.wip.wipResource/47) wt.vc.wip.WorkInProgressException: The object is not checked out and cannot be modified.
Nested exception is: (wt.vc.wip.wipResource/47) wt.vc.wip.WorkInProgressException: The object is not checked out and cannot be modified.
Nested exception is: wt.fc.ModificationNotAllowedException: (wt.vc.wip.wipResource/47) wt.vc.wip.WorkInProgressException: The object is not checked out and cannot be modified.
Nested exception is: wt.part.PartException: wt.fc.ModificationNotAllowedException: (wt.vc.wip.wipResource/47) wt.vc.wip.WorkInProgressException: The object is not checked out and cannot be modified.
We are using Windchill PDMLink 9.1 M060 & Wildfire 4 M170
Any advice would be greatly appreciated!
Chris Glenister.
ThermoFisher Scientific UK
